Sim swapped, not connected, about to travel! Need some help plz!
ConorC93
I’ve just swapped my sim as I upgraded my contract and handset from an iPhone SE 2020 to an SE 2022. I went through the process of sim swapping yesterday and my phone has yet to access the ee network. I want to make sure I’m definitely set up before I leave, but my flight is in an hour. I can’t call EE. I just get a call failed message. For example I wanted to set up a data roaming add on, but this doesn’t seem to be possible if my phone isn’t linked up to the network yet. Any advice? I’m away for a month. Am I just going to be without service? Or can this be resolved even if I’m out of the country?
cheers,
Conor
17 REPLIES 17
Hi Leanne,
Just checked and yes it does. Does that mean that the actual swap just
hasn’t happened yet?
Conor
Leanne_T
The SIM is registered if this is working for you in the old phone @ConorC93
Can you try putting the SIM back in the new phone and see if this is now up and running?
Hi Leanne,
I just turned off the one labelled at ‘primary’ and put the one I had set
to data as the ‘primary’ and it seems to have worked. Very confusing.
Thanks for your help!
Conor
Leanne_T
Hi @ConorC93
Glad to hear this is now sorted for you 🙂
Hi Leanne,
This is following our conversation on here, I got service and quickly paid
for a roam abroad pass. Then when I got off the plane in the USA, wasn’t
getting any service and when I tried to log in to clarify it said my ee
account has been blocked. I know this is a different issue, but I can’t
find any other way of contacting ee. Any idea why I might have been blocked
and how to resolve this?
Cheers
Conor
Leanne_T
Hi @ConorC93
Is your your My EE account showing blocked or the roaming and call abroad settings?
I’m not sure if the two are linked. But I assume so. I can’t actually log
into my ee account or get on to the forums. The only way I’m able to
respond to this is directly through my email. I can’t call 150 because the
roaming hasn’t started yet for some reason.
Leanne_T
Thanks @ConorC93
In this case, you would need to call us from another phone on +44 7953966250 and the team can get this looked into further for you.
