31-08-2022 03:58 PM
I’ve had my phone since march 2022 with no issues and last night my phone stopped reading my SIM card. I’ve tried resetting network settings, turning my phone on and off again, removing the SIM card from the phone and putting it back it but nothing is working. Anyone have any idea what’s happened? It’s never done this before
31-08-2022 04:06 PM
I’ve paid my bill as it comes up on the my EE app
31-08-2022 04:25 PM
Hi @Emeliz2002
Thanks for coming here.
Could you try the SIM card in another phone to see if this works for you?
Thanks 🙂
31-08-2022 06:12 PM
@Emeliz2002 It sounds like your SIM card might have failed. If you can test your sim in a different device you can also rule out the device having a fault or the sim, If it still doesn’t work in a different device then you need to request a replacement SIM card.
31-08-2022 07:14 PM
Everything’s sorted now, thanks 🙂
