Pac code
Tommoc
Hi there,
I have tried to find an answer to my question but no luck. Let's say I have an EE contract part way through it's term, I want to keep this contract but change my number. The number I want to use is pre existing.
My question is, can I use a pac code on a contract part way through to change the number of that contract. Or can this only be done at the time when you first take out a contract?
Many thanks
Matt_124
Yes you can port a number onto a contract at any time.
The number that is currently on the contract will be replaced and you would be unable to get it back.
You can port a number in by texting PORT to 150 from your EE SIM. This will then ask for the number you want to port in, followed by the PAC Code.
Just bear in mind that a PAC is for porting numbers between networks, not within the same operator.
