Number not transferring
Michelle2304
Hi I am hoping someone is able to help me. I transferred from bt to ee approx 3 weeks ago & I thought all was fine with my phone number however when I send an sms it comes up with the ee phone number which is suppose to have transferred over but when I phone someone it uses the correct phone number (my bt) I have checked my message settings and it only gives me the option to send and receive to the ee number which I don’t use.
8 REPLIES 8
Jon_K
Former EE Employee
Hi @Michelle2304
What phone are you using?
Are you able to make and receive calls?
Jon
I’m using an iPhone 11. Yeah I’m able to receive both calls and make calls. I also receive text messages it’s only when i send a text it sends on a different number.
Jon_K
Former EE Employee
Thanks @Michelle2304
If you go to Settings, then Phone, does your number display or is it a different one?
If it's a different one, can you change it to your number?
Jon
No it shows a different number, it allows me to change it but won’t allow me to save it. Rather strange it’s only outgoing messages and not calls that displays the wrong phone number.
Katie_J
Thanks for checking @Michelle2304.
If you are unable to change this I would recommend giving us a call and speaking with our technical care team.
It would be great if you could keep us updated here on the community.
Katie
Jun1nh0
I have the same problem on same phone - Did you get your problem resolved?
Having made an appointment at the EE store in Moorgate, London I went there today and the staff member was quite rude and knew nothing
Should I ring EE Community Support If so what is the number?
James_B
EE Community Manager
Hi @Jun1nh0,
Our Customer Care Team will be happy to arrange the transfer of your number if you get in touch on 150.
