on 21-06-2023 10:33 PM
hi ! I bought I uk sim , I tried to activated in Italy (where I m now ) I bought I subriscion packet .. but is still not working . I can’t call or send text … but I received text . Please can you help me ?
Solved! Go to Solution.
on 21-06-2023 11:02 PM
If this is a PAYG SIM, then it must be used on EE's UK network before roaming is activated for it to work abroad.
The only mystery here is how you received a text message abroad, this would need a connection to a foreign network which in turn needs roaming. I suspect you have been very fortunate.
on 21-06-2023 11:09 PM
on 22-06-2023 05:46 AM
No a VPN will not work.
EE Sims are designed for UK networking with roaming as a benefit (now at a cost). If you're in Italy get an Italian SIM.
