on 14-01-2023 01:53 PM
I’ve been with EE for a number of years and have just upgraded my phone. My new phone has come with a new SIM card but I would like to keep my existing number that I already have with EE. Is this possible?
on 14-01-2023 02:08 PM
@Sammiesmeex : Can't you use your old SIM? As you upgraded you should be keeping your existing no. A new SIM is sent just in case the old 1 doesn't fit.
Hi @Sammiesmeex
As long as you did do an upgrade and not an additional number, just put your old SIM in your new phone and that's all you need to do.
Does MyEE show your new plan against your existing number?
on 14-01-2023 02:11 PM
My EE is showing two numbers on my account so I’m not sure.
on 14-01-2023 02:13 PM
You should be able to see the plan against each number?
Do you have a watch plan or another service with EE?
on 14-01-2023 02:19 PM
Yes I think it’s showing as two different plans?
I have no other services with EE just the phone.
on 14-01-2023 03:18 PM
Sounds like something may be amiss then. Worth a call to EE and checking what's been ordered.
Let us know what happens.
