How to get a replacement SIM card without text?
EstherA_
Hiya my SIM card randomly stopped working and wouldn’t reset or find my network provider ?? Took it out to see scratches from wear and tear after almost 2 years in phone - why would that happen?
how do I get replacement sim quickly without text because  network is unavailable when sim doesn’t work. Unable to speak to someone as I work out of contact hours :((
James_B
EE Community Manager
Hi @EstherA_,
Physical damage to a SIM would normally only happen when inserting or removing it.
Are you able to visit an EE store to pick up a replacement?
James_B
Hi @EstherA_,
Hi thank you for responding 😄
I started getting the "no sim/invalid sim" message prior to removing
it from my phone in an attempt to reset my connection.
I will try to find a local store over the weekend that could help me.
EstherA_
