13-04-2026
06:14 PM
- last edited on
13-04-2026
08:19 PM
Kh_timi
Hi, I’m on a board and joined the roaming plan, be blocked, now I cannot use phone calling / SMS to contact EE and be blocked by online , how I solve the problem? Please help and suggest
[Mod edit: title added]
13-04-2026 07:23 PM
@genlaitn : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
