30-07-2025 11:41 PM - last edited on 31-07-2025 11:04 AM by Linzi_H
Your link which is supposed to show roaming costs - says no agreement with st Helena !!! Not very helpful!
If I buy a local SIM card from st Helena will it work in my iPhone or is my iPhone locked to EE?
[Mod edit: Add title]
31-07-2025 12:24 AM
@Leah364 : That was then, nearly 2 years ago, this is now.
When did you buy your phone new? If since 2021 it should be unlocked.
31-07-2025 08:13 AM
@Leah364 wrote:Your link which is supposed to show roaming costs - says no agreement with st Helena !!! Not very helpful!
This is the problem with adding to existing threads that are 2 years old... it is indeed "not very helpful" to do so, when starting a new thread is usually better!
That's now been done for you, and XRay's reply contains a question for you.
