unable to call while roaming
thortain
I have the roaming addon for the month, and my data is working ok. None of my calls are connecting, just says call failed. I have increased my spending cap, but calls to the UK wont connect. I've turned on roaming settings, I can also not call usa numbers.
14 REPLIES 14
Northerner
Hi @thortain
Are you on EE PAYG or pay monthly contract.
Where are you in the world.
Are you certain that your data is using a mobile network connection, and not WiFi? If you're not, then everything else tallies with roaming not being active. That causes an inability to connect to foreign networks and the rest of your symptoms naturally follow.
What are the "roaming settings" you've enabled? The only ones that matter are those on your account - the process differs between PAYG & pay-monthly. Which are you? On PAYG, this is auto-enabled once your phone is used in the UK first.
I didn't do that before leaving. I have a pay monthly contract. I'm able to use data while I'm far from any WiFi signal. I'm also able to text and receive texts from 150 and othern  mfa codes via text. Just calls say 'failed to connect' after a long attempt. I turned on roaming via connections - > Data roaming toggled on and network operator selection set to automatic.
chistery
What sort of phone do you have? Is it a fairly recent one that will likely support VoLTE roaming?
I believe it supports it, it's a Samsung Galaxy S21 Ultra 5g
Hi, I'm on pay monthly. And currently in the USA
Alex_H
Hi @thortain,
If everything else is working ok and its just the calls, it does suggest the roaming is enabled account side.
When roaming in the USA, for calls you may need to use an exit code.
If you are calling the UK from the USA, you need to use 011 in front of the 44 country code rather than the standard 00 or +, still removing the first zero of the international number. Example: 07973 100 150 would become 011 44 7973 100 150
If you're roaming in the USA and call a USA number, you'll need to use 001 or 0111 in front of the American phone number. Example of an American phone number: 321 1234567
Example A: 00 1 321 123 4567
Example B: 011 1 321 123 4567
Are your numbers in this format when trying to call? If not give it a go with the exit code attached and see if it works.  You may or may not have Roaming assistance for calls turned on which you can check in the phone app> 3 dots> Settings> Other call settings. If it is on, its worth turning it off and manually dialling the number with the exit code.
Alex
"+" in-place of the leading zero in any telephone number, is internationally recognised.
This global standard exists precisely to avoid concern for local variations.
Unfortunately, despite changing this setting and trying variations of international dialling formats all fail to connect.
