on 06-05-2025 05:28 PM - last edited on 07-05-2025 03:53 PM by Linzi_H
Ive had this problem on my S25 Ultra. Its all very well being told to call them, but when you cant make outgoing calls, getting hold of EE is quite a hassle!
[Mod edit: add title]
Solved! Go to Solution.
on 06-05-2025 05:31 PM
Your "me too" post has been moved to a new thread. Yes, you're absolutely right - travelling abroad without enabling roaming creates a natural catch-22 situation,
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
