11-09-2025 09:25 PM
11-09-2025 09:37 PM
@jotaku82 : Why shouldn't it? You're gonna either connect to the local mobile network or switch to WiFi.
You put your query in the the short title box w/out explaining yourself. Use the big text box to put your enquiry. Please clearly explain your issue & circumstances in greater detail & we'll do our best to help you with it.
11-09-2025 10:26 PM
Hello @jotaku82 ,
Welcome to the community,
Are you in Budapest?
It will depend whether you are using mobile network or are connected to wifi in Budapest, so what is your problem, not sure what help you actually want, please explain?
