eSIM
keri16
keri16
Of to New York, how do I sort phone allowance
Ali_A
Hi @keri16
You can check the costs of using your phone and bundles available on our Roaming Charges | EE Page
For New York just head to Roaming In USA
Before your trip remember to make sure your device is set up to roam by texting ROAMING to 150 (it's free)
If you're on Pay as you go, the Roaming service will already be active.
Turn on data roaming in your device settings. Check our device guides for help
By default your data is blocked while abroad and will only work if you purchase a bundle. This avoids any accidental data charges.
The bundles available will be offered once you land in your destination. They can only be purchased while in the country you are going to.
If you're on Pay monthly, check your Spend Cap is high enough to cover your daily roaming charges for the duration of your trip (we recommend at least £20). Otherwise some of your services might not work when you're roaming
Ali
