can’t call out from my phone.. i can receive calls but can’t call out only wifi.
davevena
i’m in indonesia Bali but can call out . i’ve gut worldwide roaming but still can’t call out ??
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. What is your basis for saying "I've gut worldwide roaming"?
Northerner
Hi @davevena
Did you activate roaming on your account or just buy the add-ons.
You may need to use Skype over wifi and the number in my signature to contact EE (UK office hours).
Yes roaming is on plus i have world wide sim contract..
Davevena
