on 10-12-2024 01:11 PM
on 10-12-2024 01:22 PM
It'll use your data for which you'll have needed to buy an add-on there as your UK data won't be valid there.
on 10-12-2024 02:15 PM
In common with any other internet app, usage of WhatsApp is handled by your phone and the mobile network as data usage.
If you are roaming, then mobile data will either require an add-on or will incur the daily charge.
