Voucher
Noman5
My SIM is in Pakistan, it is from the UK. I bought a new one and there is no load on it, nor is the signal coming properly, and the voucher is not being activated. The load is not being activated.
If not...On PAYG, roaming is auto-enabled once your phone is used in the UK first. Did you do this?
@Noman5 : Had you used that PAYG SIM for making calls or texts in UK before going abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
