13-02-2026 10:58 PM
My husband and I are currently abroad - outside the EU - and both our EE mobiles have been turned into very expensive doorstops!!!
We did everything we could find - which wasn't much information! - to set up our phones for 'Roaming' abroad before leaving the UK but neither of us received the text we were expecting when we arrived abroad, inviting us to buy Roaming passes for Data/calls/texts.
None of the text codes we found in Help articles are being Sent - BALANCE, DATAROAMING etc.
My husband purchased a local (Globe) SIM, but can't use it to call or text outside the country we are in - at least he has data, but it expires after a maximum 7 days whether or not used!
Very unhappy with EE!!!
14-02-2026 09:36 AM
@Ching1980 wrote:
Thanks for your reply @XRaySpeX -
When we dig deep into our respective phone Settings (mine is a Galaxy A35, hubby is A56) they are different...!
Roaming is an account-level setting which enables your SIM to connect to foreign networks. Aside from a "data roaming" option which many phones have, enabling the use of data whilst already roaming, your phone settings are irrelevant except for confirming what you already know - whether the phone is connected to a local network or not.
You've not answered "On PAYG, roaming is auto-enabled once your phone is used in the UK first. On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK. Did you do this?" but it sounds like you didn't.
I agree that you likely have EU-only roaming enabled, thus when outside the EU then roaming is effectively not enabled. Your symptoms, i.e. an ability to connect to local networks, naturally follow.
As per previous post, if you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
14-02-2026 12:12 AM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
14-02-2026 01:51 AM
@Ching1980 : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
As you never received a Welcome text upon arrival indicates that you were not set up for roaming when you arrived.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
The text DATAROAMING has never been an advised text by EE. Data roaming is just a setting on your phone to allow it to use data abroad when your roaming is enabled by EE.
14-02-2026 04:51 AM
14-02-2026 06:09 AM - edited 14-02-2026 06:55 AM
You do have only 2 options, PAYG or monthly contract. There is no monthly PAYG; it's 30-daily PAYG!
Your phone settings don't come into this at all, except to tell you you're not connected..
You had the EU roaming ability enabled but probably not Global roaming.
How long have you, being on PAYG, been there, wherever it is?
14-02-2026 09:36 AM
