Using phone in Turkey
Julia1232__
What do I need to do add calls and texts to call home when in Turkey.fp.info it before I go.i used to get bolt ones but I can't find it in app anymore
Costs for roaming in Turkey are listed at https://ee.co.uk/help/mobile/roaming/roaming-costs > Turkey
If you're on pay-monthly, ensure roaming is enabled on your SIM by texting ROAMING to 150 before leaving the UK. This enables access to foreign networks and thus coverage abroad.
Schockwave
Hello @Julia1232__ ,
Welcome to the community,
So long as you have roaming on your account, you will get the welcome message and from there you will be able to click the link to add calls and text once in Turkey.
If you are on contract, you may use your usual UK allowances in the EE ROW Zone 1 with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £5 / day or £25 / week or already have it as an Inclusive Extra or you have an EE Full Works or EE Max Plan. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/turkeyandnortherncyprus.
If you are on contract, just remember to text ROAMING to 150 before leaving UK to ensure the roaming ability is enabled on your no.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
