on 10-01-2025 02:47 PM
I am currently on holiday in Barbados and am unable to activate my roaming.
I didn't text 150 before I left the UK and recieved no welcome msg from ee when we landed.
As I am unable to activate,I am unable to call or text ee and the automated chat isn't resolving my issues.
I need roaming activating remotely.
Solved! Go to Solution.
on 10-01-2025 02:56 PM
on 10-01-2025 04:01 PM
You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
