on 09-06-2025 12:16 AM
I am a bit confused by EE’s roaming options for the US.
Are the only options now daily or every seven days?
in America for 40 days and wondering if there is a better way of covering this period. I note “full roaming” and other such packages online but the only add ons I seem to be able to add are a day or week at a time.
any help appreciated
Solved! Go to Solution.
on 09-06-2025 02:21 AM
Yes, roaming passes for US are now either 1 or 7 days. You could buy 6 x 7 days passes successively while you are there to cover your stay.
If you are on contract, you may use your usual UK allowances in the EE ROW Zone 1 with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £5 / day or £25 / week or already have it as an Inclusive Extra or you have an EE Full Works or EE Max Plan. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/usa.
As you are on contract, just remember to text ROAMING to 150 before leaving UK to ensure the roaming ability is enabled on your no.
