Turkey Receiving Texts
Blondie9
I’m abroad in Turkey. need to receive texts via UK  for two factor  authentication purposes to continue running my business in UK
I’ve tried calling EE customer service from abroad number but it’s going to voicemail. It’s driving me slightly mad as can’t call from my own phone & had to borrow someone else’s. I’ve tried texting WORLD to 150 but text won’t go through. I’ve tried turning roaming on, still no joy. Bought a local Sim only to find that doesn’t cover texts. To be honest I don’t need to send texts just receive them so not even sure I need a “pass” of any sort. Is there anything I can do via WIFI from my own phone to resolve?
1 ACCEPTED SOLUTION
@Blondie9 : Texts are free to receive worldwide provided your ability to roam is enabled.
