on 20-02-2025 10:16 AM
I am in France. You sent me a message saying I had no Spend Cap and to text back with those words but every time I press send to reply - and I have tried SO MANY times - the message is not delivered. I am totally fed up with this and have a record of all my attempts . You send me messages but every time I try to send a reply it is not delivered. At the start you said I would be charged £2.47 a day which would enable me to use your service but I cannot make any calls or texts. Please get back to me soonest.
on 20-02-2025 10:21 AM
@Soozie47 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
