SIM not working
en3ity
Hello!
Can someone help me! I'm abroad and my prepaid SIM wont work, I would not receive any codes through messages!
Can someone help me in this regard,
Rach_H
It sounds like your SIM may have gone into hibernation @en3ity.
When was the last time you used your SIM to make a call or send a text, using your balance?
Rach
9 REPLIES 9
Northerner
Hi @en3ity
Was the SIM activated on the UK EE network before you went abroad.
If not then the SIM will not work.
yes! The sim was working when i went abroad even when i went it kept
working for around 3-4 months then it didnt work!
Rach_H
Rach
Sounds like your PAYG SIM may have gone into hibernation due to non-use. If it has, topping-up now would be too late.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
Hey hello!
Thx for your reply @Rach_H .
Last time i used my sim on my ThinkPad T480 and through operator messages i was receiving everything like every code and stuff, when i turned on Data. But after that when i plugged it into a phone, it didnt work and i was not able to receiving any messages. Ive tried tuning off automatic and connecting to my local operators but that also didnt work.
Regards
Hey
I think ive passed that duration!
Its been around 1.5 year since i went abroad and it worked i think for around 6 months. And no, i didnt recharge it, btw it was prepaid! Its there any solution now?
No, you've lost it as you left it too long idle.
Oh no, is there any way to bring it back?
No!
