Roaming
Coverdale
Why don’t I get text from bank while I am in Canada with a zone1 seven day pass?
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Thank you
