11-02-2025 03:04 PM
Hi all,
I didn't manage to text ROAMING prior to arriving in France. Is it possible to activate my roaming now I'm out of the country. I obviously can't text 150 because I have no data.
Cheers!
11-02-2025 03:47 PM
Hello @DanOgunshakin ,
Welcome to the community,
Are you on pay as you go or contract? If on pay as you go, roaming is automatically enabled.If on contract, then using something like Skype you can enable it that way for free, see my signature.
11-02-2025 05:34 PM
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. Thus the reason you can't text is not because of no data (text messages don't use data), it's because you don't have coverage.
