Roaming
Tanniebee
I’m abroad, and the link for signing up for zone 1 roaming doesn’t work. I’m so annoyed, now I’m cut off from the world. Get your act together ee, this is not good enough
Christopher_G
Hi @Tanniebee
Welcome to the community.
Did you receive the 'welcome' message after you arrived? If you have a spend cap on your account, you may need to change or remove it in order to add a roaming add-on.
@Tanniebee  Did you activate roaming on your account before you left the UK ?  This is done by texting ROAMING to 150.  No billing add on enables roaming they’re just add-ons to keep costs down
Christopher_G
Hi @Tanniebee
