on 14-08-2025 12:15 PM - last edited on 14-08-2025 12:48 PM by Christopher_G
Hi.. Am currently in USA
Am on a monthly contract and my worldwide roaming was mistakenly not turned on. Had to purchase roaming package for 7 days. This is all sorted and case closed ref: ID********
My roaming will run out today and am here tul Saturday evebing Do I need another package or will my roaming be turned on.. all my details within the ref ID
Please advise! Thanks..
[Mod edit: Removed reference number from public post]
Solved! Go to Solution.
14-08-2025 01:55 PM - edited 14-08-2025 01:56 PM
Yes as @Schockwave has said you should already have this in your plan if it was taken out this year (on or after 29th August 2024), provided via the Roam Further Pass add-on - meaning there shouldn't be anything you need to do outside of the Roaming capability being enabled (which it must be if you can connect to US networks).
Your Inclusive Extra options won't show any Roaming Passes if this is the case, as they would all be built into the plan ("Roam in EU" for EU Roaming & "Roam Further Pass" for ROW Zone 1 Roaming).
I will attach a screenshot of the add-on from my own Full Works plan to show what this should look like:
Having the "Roam Further Pass" should mean you are able to use your allowances in the USA free-of-charge (subject to a 50GB Fair Usage Policy on Data) and shouldn't be asked to buy a pass.
on 14-08-2025 12:17 PM - last edited on 14-08-2025 12:47 PM by Christopher_G
Am on a monthly contract and my worldwide roaming was mistakenly not turned on. Had to purchase roaming package for 7 days. This is all sorted temporarily and case closed ref: ID*******
My roaming will run out today and am here tul Saturday evening. Do I need another package or will my roaming be turned on.. all my details within the ref ID
14-08-2025 12:19 PM - edited 14-08-2025 12:21 PM
@Xerxes1 : When your current roaming pass expires you will be sent a text offering you a new 1.
This user discussion forum can have no access to your specific account & so has no idea of what's in your case.
on 14-08-2025 12:35 PM
Thanks @XRaySpeX but if my roaming will be turned on I dont want to have to do that.. such a performance.
Superb username btw.. made me smile.. Have a fab day..
on 14-08-2025 12:38 PM
As your roaming ability is already on it won't change. It's only the billing add-on you need.
on 14-08-2025 12:42 PM
I have had roaming in my contract forever as I travel for work.. it just wasn't turned on when I upgraded my phone.. it was a mistake.. and the agent was lovely sorting it out temporarily..
Am back on the road later with no WiFi.. cannot call the ee number to sort again..
14-08-2025 12:43 PM - edited 14-08-2025 12:44 PM
If you are able to connect to US networks, your capability to roam onto foreign networks is switched on (Roaming is switched on).
I suspect what you're referring to instead is a billing add-on related to ROW Zone 1 Roaming charges.
Are you on an All Rounder or Full Works plan taken before 29th August 2024 by any chance? If so your Inclusive Roaming is dependent on an Inclusive Extra being selected; namely "ROW Roaming Pass" for the USA.
Have you tried going to Mobile Add-ons > Inclusive Extras > Change Inclusive Extra & selecting Roaming Pass ROW in your EE App or Online Account?
If the above does not apply, what plan are you on and when was your contract start date?
Thanks @Matt_124 I jave the full works amd my contract was renewed earlier this year... will try but the agent couldn't turn it on for me last Saturday and said I needed to call again and get switched on when I get home..
Unable to call ee to have a look.. will give your suggestion to try myself a go.. thank you.. 😊
on 14-08-2025 01:37 PM
@Xerxes1 ,with full works, it should be automatically included, but EE should have text you and let you know with the welcome text.
