Roaming pass
Snuffbeastly
I purchased a roaming pass and n uk and am now in Canada. Do I need to turn data roaming in settings on?
6 REPLIES 6
Northerner
Hi @Snuffbeastly
If you did not activate roaming then you'll need to activate this with EE. Use Skype and the number in my signature to call them.
Data roaming in your phone settings enables the use of mobile data whilst roaming. If you have a local network connection and can't use mobile data, then this is likely a cause. On the other hand.....
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Snuffbeastly
Thanks everyone for help. Deleted and reinstalled app and it’s all up and running now.
Don't see how the app can affect your ability to roam in Canada.
Katie_J
Thanks for coming back to let us know @Snuffbeastly.
Katie
