Roaming not working
Cherry6755
I arrived on the 13th and get no network? I have spend cap of 20 pounds before I left the UK. Why can't I get no calls or make calls. 😕
7 REPLIES 7
Cherry6755
The phone says no network registered 😑 so I can't get to phone 150 EE or even email 🤔
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Cherry6755
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
NO
I spoke to EE advisor last month That wasn't explained unless I missed something?
What is "NO" in response to?
Leanne_T
Hi there @Cherry6755
Have you tried manually connecting to a different network?
Did you receive a text message when you arrived from EE?
Speak soon.
Cherry6755
I haven't received no text what so ever. Nothing. I. So disappointed right now I have some important texts and can't receive anything
Cherry
Leanne_T
Thanks for coming back to us.
Do any networks show available if you manually try and search in the device network settings?
