Roaming not working
Sandraw1
I also have this problem.  I did not text Roaming before I left England.  Now although I have paid £25 for roaming I cannot use my phone.  The online chat is useless.  I do not have access to another phone.  Is it possible to use WiFi to phone EE?
Your post has been moved to a new thread, but as per one of the first replies in the thread you'd added to..
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
@Sandraw1 : You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Thank you, I have now resolved this issue by downloading Skype to my mobile phone.  It took about 30 minutes to eventually speak to someone from EE.  They sorted it for me.  Everything now working.
