Roaming in Russia
elenatoo
Valued Contributor
Valued Contributor
Hello,
I am travelling to Moscow Russia. Can I use roaming there? How to switch it on in Russia?
Thank you,
On PAYG, this is auto-enabled once your phone is used in the UK first. On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
Roaming costs can be found at https://ee.co.uk/help/mobile/roaming/roaming-costs
elenatoo
Valued Contributor
Valued Contributor
Thanks a lot!
