Roaming in Canada
Wong5
Hi, I'm a pay as you go customer.  how do I buy a Canada Roaming package? Thanks.
1 ACCEPTED SOLUTION
There's no roaming passes on PAYG outside the EU. You cannot use your usual UK allowances outside the EU but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/canada > PAYG.
Wong5
how does the "data add-on" work?  how many GB within e.g. one week?
You've added to a thread about Canadian roaming, so I'll presume that's the country you're querying.
The daily & weekly add-ons allow access to your UK allowances, subject to an FUP for data. So whatever UK allowances you have for calls & texts, applies in Canada. The same goes for data, but with a 50GB FUP if your allowance is greater.
@Wong5 : You'll be offered these data add-ons on PAYG for Canada:Capture.PNG
