Roaming data
Cfaigyboy60
I am in tenerife I didn't get roaming data before I flew here ,how do I get it now I am here ?
6 REPLIES 6
Northerner
Hi @Cfaigyboy60
Are you on EE PAYG or pay monthly contract.
If pay monthly did you activate roaming on your account. Have you any spend cap in place.
tangkhg
Valued Contributor
Valued Contributor
Hi @Cfaigyboy60
If you connect to any local wifi, and then sign into your EE app, you will be able to a) remove your spend cap from your phone, and b) enable roaming.
However, probably much cheaper to buy a local sim!
@Cfaigyboy60 : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
@tangkhg : You cannot b) enable roaming using the EE app; only by texting ROAMING while in UK or calling CS.
tangkhg
Valued Contributor
Valued Contributor
@XRaySpeX
Ummm... I can?
@tangkhg : All that's gonna do is offer to sell you roaming billing add-ons to help pay for your roaming ("use your phone abroad w/out spending too much") but it won't actually activate roaming on your a/c.
