Roaming blocked
Rebecca12414
Hi I’m having a major issue
im in Italy but my roaming is blocked for calls and texts, texts won’t send and when I call it just says I’m blocked from making calls
when I go on EE chat it says text 150 to set up but I can’t text then it says call but I can’t call so how am I supposed to sort it? Driving me mad
anyone have any idea on how to fix it?
8 REPLIES 8
@Rebecca12414 This will be because you didn’t text roaming to 150 before you left the UK do you activate roaming on your account so you can connect to a roaming network ,  you now need to contact customer support via live chat so you can request roaming to be enabled on your account.  Live chat is available via the EE app under help.
Live chat won’t put you through to technical support, can only call so frustrating
 Never had this issue before, and I received the normal text when I landed so I’m not sure why it’s now been disabled
@Rebecca12414  if you got that text then roaming is definitely enabled. Have you tried restarting your device? Have you tried a manual network search ?
yes restarted but still won’t connect, and messages still won’t send really wierd,
I’ve tried turning off the automatic network and selecting one myself but it still won’t let me call or text
not sure what to do
Sorry don’t mean connect mean it connects to a network but won’t let me call, wrong wording
@Rebecca12414 , have you tried to manually search for a network that works for you, if you have indeed received the welcome message? Go to settings, mobile services and then switch off automatic network and see what other networks are there under network selection.
DantheSwan
Are some posts not showing up for you?
They've already done what you proposed
Technical support are an offline team and are not customer-facing.
There are customer-service teams who have a little more systems access than frontlline agents who answer inbound calls, those agents have access to fault ticketing into network-engineering & support areas.
In your case - what I don't see having been ruled out is a spend-cap or international call bar issue. Spend-cap can be self-checked via https://ee.co.uk/help/mobile/manage-use/pay-monthly/set-up-and-manage-spend-cap
