on 19-02-2025 03:57 PM
I appreciate that this may have been asked before, but as product names etc seem to change then I thought I would specifically ask - are Indonesia and Singapore included in the Roam Further Pass?
If not can these be added via another pack?
TIA!
Solved! Go to Solution.
on 19-02-2025 06:50 PM
Hi @Retrofire,
Welcome to the EE Community
Indonesia and Singapore are not included in the Roam Further pass, but they would come under Zone 1 of the new roaming add-ons which you can read more about here Roaming Refresh
As @Northerner mentioned you will get a text when you arrive and connect to the local network which will give you the option to purchase the available add-ons.
Alex
on 19-02-2025 05:55 PM
Hi @Retrofire
You'll receive a text with add-ons and costs when you arrive.
Make sure roaming is activated on your account.
https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/indonesia
Hi @Retrofire,
Alex
on 19-02-2025 08:03 PM
No, you need to buy the daily or weekly Zone 1 Pass.
