Recieving txt message abroad
Khd1986
I did t activate roaming and I can't find how to activate it through my re account I need to access an important txt message ASAP
You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
