Reached Spend Cap message - Unable to make roaming calls
Jonhad33
Any ideas ? Have never had roaming problems and do not have a spend cap (checked EE App) but cannot make any calls in USA now. Had no problems 4 months ago when here and customer services do not seem to have a clue!
mnsb
Just got back from the US.  Exactly the same problem.  Also, like you, customer services didn't have a clue.
Rach_H
Hi @mnsb
Welcome to the Community!
Are you able to make callsabroad now you are back, or is this not something you've had a chance to try?
Rach
