on 25-08-2024 09:32 AM
I am in Spain having same problem. Whenever I try to call someone it cuts off immediately. Roaming is on have tried all settings but can’t make outgoing call
on 25-08-2024 11:38 AM
@Chellep73 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
