05-11-2025 09:39 AM - edited 05-11-2025 09:41 AM
I have a pay as you go sim. I’m in Thailand at the moment and the phone is useless. I cannot send messages or call the UK . How do I fix this urgently
05-11-2025 09:52 AM - edited 05-11-2025 09:53 AM
If not...On PAYG, roaming is auto-enabled once your phone is used in the UK first.. Did you do this?
05-11-2025 10:05 AM
I did not use phone in UK as I had urgent travel plans . I changed from a monthly plan to Pay as you go and it changed over when I got here . I cannot seem to do anything now and it is impossible to get CS . I did get a welcome message yesterday saying calls cost £1.80 / min and texts 60p . But I still cannot use these services . I put £5 credit on and still no bloody good
05-11-2025 10:10 AM
All new PAYG SIMs need to be activated on EE's UK network, before roaming is auto-enabled for use abroad. This includes migrations from pay-monthly.
Now that your SIM is a new PAYG one, it therefore needs usage in the UK before roaming is enabled. If you've not done this, it will not work abroad until it's first used on EE's UK network.
06-11-2025 12:22 AM
Thanks for that, if I convert it back to a monthly plan will I be able to use it then ? Perhaps I should not have changed from my original monthly contract before leaving ?
06-11-2025 12:28 AM
Probably not.
06-11-2025 12:39 AM
So what you’re saying is that my number is redundant unless I return to the UK ? I had a monthly plan on this same number for many years and changed to PAYG just before it changed over . So what can I do to get this UK number to work ?
06-11-2025 08:13 AM - edited 06-11-2025 08:25 AM
@Duggyr wrote:So what can I do to get this UK number to work ?
Pay-monthly users can enable roaming via CS remotely, however you then have the issue of a new SIM needing activation whilst abroad - it may work, but it comes with no guarantees.
01-12-2025 09:32 AM
Thanks,
I came across the same situation, and seems the only solution for this is to come back to UK.
Wondering how long can I keep this number for (not deactived by the system) if I can't text and make call, or any other suggestions to prevent this number from being deactivated while I can't make call and text until I go back to UK?
Many thanks.
01-12-2025 10:32 AM
@hz2019 : A PAYG SIM goes into hibernation after 279 days of non-chargeable activity.
