No network
Profile closed
Not applicable
I'm travelling and have no signal whatsoever, tried every which way to restart, reboot etc - impossible.
The most frustrating thing however, is no one at EE is answering any messages on social media and due to my problem, I cannot call or text them.
Absolutely impossible and such poor customer service…
any advice?
10 REPLIES 10
Are you travelling in the UK or abroad?
Profile closed
Not applicable
Abroad
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Profile closed
Not applicable
I’m afraid this isn’t helpful, as mentioned, I cannot make calls or texts. EE haven’t replied to my messages via social media, which is quite shocking….basically there’s no way of contacting them. Really poor.
Yes, there is! Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Profile closed
Not applicable
I have no signal to make any calls. To be honest EE should be ashamed. They haven’t attempted to contact me back. Shocking service.
@Profile closed wrote:
I’m afraid this isn’t helpful, as mentioned, I cannot make calls or texts. ….basically there’s no way of contacting them.
As per the final paragraph of my previous post...
Travelling abroad without enabling roaming does cause a catch-22 situation, as you have found out.
Profile closed
Not applicable
and with no response or care in the world from EE, there is no solution. Absolutely shocking service.
