02-08-2026 11:33 PM
Appalling! My daughter has just landed - first holiday on her own - phone not working can’t access the app or website
02-08-2026 11:55 PM
Fix an EE phone not working abroad, restart your device, turn off automatic network selection to choose a local network manually, and verify that data roaming is enabled in your phone settings and your EE account
Im assuming you have tried this?
03-08-2026 08:38 AM - edited 03-08-2026 10:04 AM
Welcome to the Community, @rlprice1me.
Fingers crossed some of the above @Chris682 has recommended will do the trick - sometimes phones just need a bit of extra coaxing to recognise a roaming network, and even I've had instances where I've needed to do a restart to get things working when I land.
It's worth double checking to make sure she hasn't accidentally toggled roaming off in the phone's settings - just be aware this is independent of any roaming settings at our end, so does not guarantee the ability to roam.
If none of this makes a difference, please give our team a call, and they'll be able to check over all the roaming settings at an account level too.
Peter
03-08-2026 11:46 AM
@rlprice1me , if on contract, have you your daughter made sure that roaming is enabled on the account?
03-08-2026 12:26 PM
Data roaming is a phone setting allowing use of mobile data whilst already roaming.
Roaming is an account/SIM-setting allowing access to foreign networks.
That network access allows use of calls, texts & mobile data.
