14-05-2025 12:56 PM
I am absolutely fuming...... I had my phone set up in the U.K by a guy named Kris, who told me about his expertise with the company. I am now in the U.S.A and can not make any calls and can not receive any calls. I am here for 2 months and now have no way of using the phone. As soon as I dial a number, it says "call ended". EE give a number to call, but is useless, as I can not make any calls.
17-05-2025 12:03 AM
How can I dial freephone number when I can not make any calls ?????
17-05-2025 12:10 AM
You mentioned being able to access social media sites, if you're doing this over the mobile network and not WiFi then you have a network connection and are thus roaming. EE CS therefore have nothing to enable.
Try performing a manual network search, and connect to each local network in turn. Do they all give the same problem? Or does another network provide service?
17-05-2025 12:34 AM
Try turning off 5G. I had the same issue and this seems to have fixed it.
