No calls in or out from U.S.A.
SusieSeal
I am absolutely  fuming...... I had my phone set up in the U.K by a guy named Kris, who told me about his expertise with the company. I am now in the U.S.A and can not make any calls and can not receive any calls. I am here for 2 months and now have no way of using the phone. As soon as I dial a number, it says "call ended".  EE give a number to call, but is useless, as I can not make any calls.
12 REPLIES 12
@SusieSeal   Did you enable roaming on your EE account before you left the UK ?  This is done via texting ROAMING to 150.  The setting up of your device nothing to do with roaming as it’s an account function not a device setting,
@SusieSeal : Did you receive a Welcome text upon arrival?
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
Yes, I make this trip 3 times a year
I make this trip 3 times a year, everything was set up by EE before I left the uk
Every time I dial a number  , it just says " call ended
FYI you have a short time to edit replies, negating the need for multiple short posts - everyone can see every post.
Can you send & receive texts? Can you use mobile data?
Have you been able to make or receive calls abroad in the past? If yes, on this trip or a previous one?
@SusieSeal , have you tried a manual search for a network to see if you get any network and can then make a call and text and receive them?
No I can not text, I can access Facebook, etc. I have been ableto make and receive calls in the past on previous trips
yes
