Need Assistance My Number not working abroad
PAULBASSAM
@PAULBASSAM : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
PAULBASSAM
My number is Pay as you go. I used my number before i left. and i also bought data and topped up my phone. the last top up was in september.
Linzi_H
Thanks for letting us know @PAULBASSAM
If you have enough credit to make calls (check the roaming costs for where you are) and buy the data add-on you're looking at, then it will be best to contact us using the details we've sent to you. From there the team can review your account to see what's happening exactly.
Linzi
