My phone is saying no sim and can’t use my phone of data abroad
Jacktaylor1
I need help and contacting asap as I’m in Egypt and can’t use my phone of data
12 REPLIES 12
Northerner
Hi @Jacktaylor1
It sounds like you don't have roaming activated on your account. Assume you did not receive a welcome text.
You'll need to use another device and contact EE here: https://ee.co.uk/help/contact-ee
You can also try the message feature on the EE app on WiFi.
Christopher_G
Hi @Jacktaylor1
Welcome to the community.
I recommend following @Northerner's advice and speak with our customer support team, as soon as you're able to. They'll be able to do some checks on how your SIM is set up, and help make sure you choose the right plan for your trip.
Let us know how you get on please.
@Jacktaylor1 : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
@Jacktaylor1  If the phone is saying “no sim” take it out and give it a clean.  Having roaming enabled will not help if the phone can’t see the sim.  Phones will say no sim if it’s a faulty sim or the sim needs a clean.
I’ve pulled the sim out nothing is working I’ve had this new phone just over a month now
Sent from my iPhone
@Jacktaylor1  you have two issues one being no sim in device shown, so have you cleaned the sim and put it back in ?  Use a damp cloth and make sure it’s dry before you put it back in.
And issue two is,  did you enable roaming on your account before you left the UK, if not you’ll not connect to a roaming network as roaming being enabled is an EE account option.
 Does the device still say no sim ? After it’s been cleaned and put back in to the device?
Yes I’ve tried everything I need someone to contact me asap to sort this out as I’m in Egypt with no phone or data and unable to contact ee myself
Sent from my iPhone
No one will contact you from this user discussion group other than thro' the medium of these forums by posts such as this. Anyway we haven't the faintest idea who you are. You need to phone CS.
Like I’ve said I’m unable to contact you due to phone saying no sim and can’t make calls text or use data you have my email to pass on to someone who is capable of helping me I’ve gone nearly a week now for this to be fixed and no one has helped or even tried to help me which is a little bit frustrating as when I get this new phone I was told eu roaming was on and ready for me to use when I went away which isn’t the result my contact number on the contact is ********* my name is Jack ***** and my email is ****************
Sent from my iPhone
[Mod edit: Removed personal information]
