Mobile function in Greece
Filippos89
Hello, I am currently in Greece and my phone does not work at all. I can not receive or make calls. Only texts I can receive but I can not send any of them. I activated a 7 days add on but the phone still does not work. I have an indication of the voicemail always on as well.
As it was switched to PAYG while you were abroad you can't now use it until you return to UK. EE PAYG SIMs need 1st activating on EE's home UK network before they can be used abroad.
7 REPLIES 7
@Filippos89  if you tried just restarting the device? Have you tried manual selecting a different network?
@Filippos89 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
That did not work but thank you for your response!
Thank you very much for your response. I changed from contract to PAYG phone while I was abroad so probably that's the issue. I have an esim so I thought it wouldn't need to be in the UK. I will call them tomorrow at the free line number and I hope we will solve it.
Thanks again for your response and your time!
