on 06-01-2025 04:04 PM
I have a compressive all inclusive contract with EEin the uk. This includes extended roaming to include Australia but my phone can’t make or receive any calls here in Oz. I’ve made sure the settings are correct, tried rebooting etc but with no joy. Can someone help please.
ps. Can’t even call EE!
Solved! Go to Solution.
on 06-01-2025 04:24 PM
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. You mention "settings are correct", but which settings are those? The only that matters, is to enable roaming on your SIM. I suspect you've not done this.
on 08-01-2025 12:01 AM
The toggling to other available providers rather than Auto worked . Thanks very much for your help.👍👍👏👏
