I can't send or receive calls in the USA, despite me being on the £25.00 roaming
kimD2
Hi, I am stuck in the USA and cannot use my mobile for calls or to receive messages. I get messages to say a message has been left.
I have tried all of the different numbers suggested - and also tried to call out - but its just dead.
The network is 4G Verizon - my phone is a Samsung 9
I have paid for the £25.00 7 day pass - and everything else seems to work - mobile data to wifi, etc.
I am in a catch 22 situation - EE doesn't have an email help solution and keeps saying I have to call if I have a problem.
Any ideas?
K:-)
@kimD2 : I dunno if "mobile data to wifi" means you can use mobile data or just WiFi.
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Like I’ve said in other posts calling from the USA to the U.K. has been an issue for me since last  summer and as yet there is  no resolution to this, so I’ve been told.
As this is a known issue my experience has been to up your spend cap allowance and as long as you have a global add on set in place on a monthly contract the amount should be refunded.
