How to active roaming in Pakistan
Badsha1
Please Answer me
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
You'll receive a Welcome text upon arrival at a country giving your roaming options.
If you are on contract, you may use unlimited calls & texts & 500 MB data per day in the EE ROW Zone 3, when you buy the Zone 3 Pass for £7.50 / day. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/pakistan.
If you are on contract, just remember to text ROAMING to 150 before leaving UK to ensure the roaming ability is enabled on your no.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
