Hi using my phone in pakistan
Imranjalal
1 ACCEPTED SOLUTION
Are you intending to go there or are you already there?
You cannot use your usual UK allowances outside the EU but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/pakistan.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
